Warm Start Issues |
Warm Start Issues |
Ken Mikos |
Aug 12 2020, 08:57 AM
Newbie Group: Members Posts: 28 Joined: 20-February 14 From: Pgh Member No.: 17,024 Region Association: None |
My 73 914 1.7 With factory FI just doesn’t want to restart after a warm shut down. The motor turns but it just wont start without a lot of coaxing. Any thoughts or suggestions ?
+ Do you think warppinng the fuel lines would help ? + Is it vapor lock ? + almost seems like the car is Flooded ? Thanks in advance for your replies. Ken |
saigon71 |
Aug 12 2020, 10:36 AM
Senior Member Group: Members Posts: 1,995 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My 73 914 1.7 With factory FI just doesn’t want to restart after a warm shut down. The motor turns but it just wont start without a lot of coaxing. Any thoughts or suggestions ? + Do you think warppinng the fuel lines would help ? + Is it vapor lock ? + almost seems like the car is Flooded ? Thanks in advance for your replies. Ken Hi Ken: I don't think wrapping the fuel lines will help. I do indeed think it is vapor lock. I battled this problem for years. The fix is to relocate the fuel pump up front either by using tha Autoatlanta kit or sourcing a mount from the 75-76 model year and installing it under the tank. |
Frankvw |
Aug 12 2020, 10:51 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
well..there is not a lot of info to help analyze. Could also be CHT malfunction and thinks it is cold and gives too much fuel. Could be coil that is on his last legs...etc. More info available ?
carlsol |
Aug 12 2020, 02:39 PM
Newbie Group: Members Posts: 12 Joined: 3-January 15 From: Raymond, NE Member No.: 18,283 Region Association: Upper MidWest |
I agree, good chance it's vapor lock related. I had the same warm start issue with my 73 2.0.
Problem was solved completely by relocating the fuel pump as the prior post notes. Good luck |
Ken Mikos |
Aug 13 2020, 07:01 AM
First off thanks for the replies. The car starts on the first crank when its cold, only after driving (mostly on a hot day) does it not want to run. Will look into relocating the pump. THANKS AGAIN
Lo-Fi Version | Time is now: 19th April 2024 - 11:32 PM |
