SOLD DLRA Dellorto 40's, NOW $510 |
nditiz1 |
Aug 4 2020, 04:03 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
SOLD
Nice used set in working condition. These were running on my 74 2.0 and were pulled as a test to try different carbs regarding my overheating issue. I have the corssbar linkage if you so desire. Will throw in the CB performance intake manifolds and decent used spacer gaskets so its a complete bolt on if someone wants to go that route. $600 for the carbs bolt on ready NOW Edit* CSP Linkage is NLA - Crossbar will go with the Dells, unless I can talk you out of it. Main - 140 Air - 180 Idle - 60 Vents - 34 (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1597144969.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1596890771.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1596578626.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1596578796.1.jpg) |
jaredmcginness |
Aug 6 2020, 05:48 AM
... Group: Members Posts: 501 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
I'll be tempted to pick these up when I am back in MD in a few weeks if still available.
nditiz1 |
Aug 6 2020, 07:57 AM
Hey Jared,
If they are that would be an easy transaction since I don't need to ship. I sent you a PM on a possible pkg deals for my 2.0 engine I will be pulling. Nick |
drifter914 |
Aug 6 2020, 08:17 AM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
So, I need to ask... were these carbs the source of the over heating issue ?
(IMG:style_emoticons/default/sad.gif) |
nditiz1 |
Aug 6 2020, 08:20 AM
They were not. I swapped over the Weber IDFs I had and the issue was the same. So that test did two things. It told me that the Dells were in good working order AND that it made me dig deeper into finding the issue. Huge leak between cylinder and head. 30% leakdown loss.
nditiz1 |
Aug 7 2020, 11:38 AM
Weekend price drop
$575 for the bolt on dellortos with hex bar. |
nditiz1 |
Aug 10 2020, 03:00 PM
RTR (Ready to Run) Carbs
Another drop $550 for the below: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1597093244.1.jpg) |
nditiz1 |
Aug 13 2020, 05:11 AM
$530 Bump
nditiz1 |
Aug 16 2020, 02:53 PM
Another $20 off, $510 NOW
Pair this with a nearly new Pertronix SVDA I'm selling and you will be on your cruising way. |
flat4guy |
Aug 16 2020, 05:10 PM
Member Group: Members Posts: 442 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
I have these on my 71 - good carbs. GLWS
JamesJ |
Aug 18 2020, 06:17 PM
Member Group: Members Posts: 219 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hello...a couple of ?s
Can you tell me why you did not reinstall these after you determined they were not the source of the heating problem? I have a pair of Weber 40s on a 2.2 four cylinder. They seem to work fine. How would you compare drivability and performance between the two types of carburetors? |
nditiz1 |
Aug 18 2020, 07:02 PM
@JamesJ - I actually removed the webers as well. I don't need two sets of carbs in my house with no 4 cyl to run them on. After it was determined that the issue with overheating was due to the engine and not anything else I decided to abandon the 4cyl. Im going to keep the webers and throw them on my beetle since I have several jets and pieces for webers. If I had not already invested in weber jets and venturis from my previous 914 I would be selling the webers since the Dells seemed more powerful. They seemed to have a better midrange which is where I usually find my street driving.
JamesJ |
Aug 18 2020, 09:11 PM
I see. I think the Webers are a bit choppy around town and wondering if the Dells might smooth things out a bit. I appreciate the feedback and am going to do some more research.
Lo-Fi Version | Time is now: 19th April 2024 - 12:35 PM |
