Further speedo drive seal issues,, found my problem..I think. |
porschetub |
Jun 2 2020, 10:05 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Small leak @ the angle drive,done the housing seal and while under the car found the leak was coming out the cable drive and leaking down there.
Sure I had a shaft seal that I bought some time ago and after a search think I found it. Can anyone confirm it is 10 x 18 x 6mm ?. TIA. |
Jun 3 2020, 08:45 AM
date='Jun 2 2020, 09:05 PM' post='2821572'] Small leak @ the angle drive,done the housing seal and while under the car found the leak was coming out the cable drive and leaking down there. Sure I had a shaft seal that I bought some time ago and after a search think I found it. Can anyone confirm it is 10 x 18 x 6mm ?. TIA. [/quote] Tip on removing the old seal. Carve out the pladtic with a knife. Screw in a lug bolt (14 x 1.5 ). It will catch the lip of tbe metal vup and pull it out. The washer sticks to the top of the seal. Dig it out first. I have a new batch of the speedo drive bushings reworked with the second groove to reduce leaks. Or if you have access to a lathe cut a second groove the same size as the oroginal groove. |
porschetub |
Jun 3 2020, 02:39 PM
[quote name='bdstone914' date='Jun 4 2020, 02:45 AM' post='2821668']
porschetub date='Jun 2 2020, 09:05 PM' post='2821572'] Small leak @ the angle drive,done the housing seal and while under the car found the leak was coming out the cable drive and leaking down there. Sure I had a shaft seal that I bought some time ago and after a search think I found it. Can anyone confirm it is 10 x 18 x 6mm ?. TIA. [/quote] Tip on removing the old seal. Carve out the pladtic with a knife. Screw in a lug bolt (14 x 1.5 ). It will catch the lip of tbe metal vup and pull it out. The washer sticks to the top of the seal. Dig it out first. I have a new batch of the speedo drive bushings reworked with the second groove to reduce leaks. Or if you have access to a lathe cut a second groove the same size as the oroginal groove. [/quote] Found the original packaging and all is good I have the right one. Thanks for the tip Bruce ,never done one of these before (IMG:style_emoticons/default/beerchug.gif) . |
Lo-Fi Version | Time is now: 24th April 2024 - 12:09 PM |
