FS Heater J Tube block off plates for cars with out heat, Set of two plates with hardware - $27.50 per set shipped |
Apr 1 2020, 11:34 AM
Edit, Have ten more sets available.
I have seen many cars that deleted all of the heater parts and left the J tube holes in the tins open where the fan can suck hot air in. I made these to cover the holes and look better than a paint cap stuffed in the hole. I can supply them bare if you want to paint to a special tin color. Had them made from .047" mild steel. Bent the tuck tabs by hand. Each set consists of two plates , 6mm socket head screws. washers and nuts. Price is $27.50 per set shipped. PMs will be sent to those who replied to this thread. Attached thumbnail(s) |
BPic |
Apr 1 2020, 11:36 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
YES PLEASE! 1 - Set
Jim C |
Apr 1 2020, 12:20 PM
Member Group: Members Posts: 189 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
I have seen many cars tha deleted all of the heater parts and left the J tube holes in the tins open where the fan can suck hot air in. I think I could makes these fairly inexpensively. Price would be $20-$25 a pair. They would be powder coated black and attach thru the hole in the tin that is for the J tube attachment screw. I'd be interested. |
Gint |
Apr 1 2020, 12:25 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
At that price, I'd take a set to put on the shelf. I'm in for one.
abes914 |
Apr 1 2020, 12:32 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
i am in for one as well.
Literati914 |
Apr 1 2020, 12:49 PM
Senior Member Group: Members Posts: 1,433 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Yes I'd like a set as well.
DMAYHALL |
Apr 1 2020, 03:10 PM
Newbie Group: Members Posts: 13 Joined: 26-June 14 From: las vegas Member No.: 17,557 Region Association: None |
I'm in for a set !!!
Alapone |
Apr 1 2020, 03:30 PM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
id take a set
Apr 1 2020, 04:13 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I think a better solution is something like this. These could be powder coated or maybe could even be found already black. Even some plastics could be acceptable - the factory J-tube delete cap on the passenger side is a polyethylene plastic.
Attached image(s) |
Apr 1 2020, 08:49 PM
@JeffBowlsby
I think a better solution is something like this. These could be powder coated or maybe could even be found already black. Even some plastics could be acceptable - the factory J-tube delete cap on the passenger side is a polyethylene plastic. [/quote Good idea but I do not find that type of metal cap plug available in sizes over 2". Larger plastic plugs are available but the only ones I found were bright green. Also the clearance to the vertical wall on the cylinder tin is only 3mm so the head may hit. One issue I see is that most tins are bent up and the plate may not sit flat. |
Optimusglen |
Apr 2 2020, 07:43 AM
Senior Member Group: Members Posts: 901 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
I'm definitely in for a set.
Jim C |
Apr 2 2020, 07:58 AM
I found some 3" flat black plastic plugs on Amazon which, along with some black RTV, covers the holes. For how long I don't know. I am certainly open to a more permanent solution.
Craigers17 |
Apr 2 2020, 09:56 AM
Senior Member Group: Members Posts: 728 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
I'm in for a set.
Apr 25 2020, 08:07 AM
Bump. Should have finished parts in about one week.
Apr 29 2020, 01:28 PM
Bump, available now.
Jim C |
Apr 30 2020, 09:39 AM
@BPic @jim C @Gint @abes914 @Literati914 @DMAYHALL @Alapone @Optimusglen @Craigers17 I'll take a black pair Edit #3. Plates are made and getting powder coated satin black today. I can supply them bare if you want to paint to a special tin color. Had them made from .047" mild steel. Bent the tuck tabs by hand. Each set consists of two plates , 6mm socket head screws. washers and nuts. Price is $27.50 per set shipped. PMs will be sent to those who replied to this thread. I have seen many cars that deleted all of the heater parts and left the J tube holes in the tins open where the fan can suck hot air in. I think I could makes these fairly inexpensively. Price would be $20-$25 a pair. They would be powder coated black and attach thru the hole in the tin that is for the J tube attachment screw. |
JamesM |
Apr 30 2020, 09:56 AM
Ive thought about doing something, always hated that open hole. Ill take 3 sets.
Literati914 |
Apr 30 2020, 10:08 AM
payment sent. Thanks Bruce!
abes914 |
Apr 30 2020, 11:45 AM
Payment sent. Thank you!
Craigers17 |
Apr 30 2020, 03:34 PM
I might have missed it somewhere, but what is your preferred payment method? I'll get you the funds ASAP. Very Nice work....thanks!
-Craig |
Lo-Fi Version | Time is now: 24th April 2024 - 07:58 AM |
