Early vs Late Windows |
rcarson25 |
Jan 18 2020, 05:25 AM
Member Group: Members Posts: 62 Joined: 15-May 17 From: TN Member No.: 21,103 Region Association: South East States |
In the midst of a 1970 rebuild and I have a 1976 parts car. Is there any benefit to switching from the early window/regulator setup to the later style window/regulator setup? are The later style components any better or more reliable or should I just stick with the early window components and move on to another part of the car?
rgalla9146 |
Jan 18 2020, 06:52 AM
Advanced Member Group: Members Posts: 4,538 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
In the midst of a 1970 rebuild and I have a 1976 parts car. Is there any benefit to switching from the early window/regulator setup to the later style window/regulator setup? are The later style components any better or more reliable or should I just stick with the early window components and move on to another part of the car? Later regulators are better overall, windows seal better at the front and don't rattle. Later regs can be adapted to early doors. A bit of fabrication is necessary. You'll need all the later parts including the glass. How good are the '76 doors ? |
rcarson25 |
Jan 18 2020, 07:09 AM
swapping the doors is not really an option at this point. The project car has been painted, so if I were to do it I would have to be able to swap parts over without killing the paint.
Jan 18 2020, 07:16 AM
914 Guru Group: Members Posts: 8,844 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
It can be done but not practical at this point. Probably should have been done when you were assembling body for paint.
rcarson25 |
Jan 18 2020, 07:40 AM
Yeah definitely would have been easier, but who ever makes a project easy right? Unfortunately I didn’t have the parts car until well after the project car was painted. Thanks for the input, sounds like it saved me a ton of time fighting the conversion.
Lo-Fi Version | Time is now: 28th March 2024 - 01:19 PM |
