3 Pages V  1 2 3 >
> Time for a rebuild?, Time for a rebuild
Wew
post Jan 17 2020, 06:06 PM
Hi All,
I love this community. I have used the search function a bazillion times to gather invaluable information to help troubleshoot and DIY's on my 73 2.0 fuel injection.
I have been working on the body for years and have it in pretty good shape. The interior as well is almost done. I have gone through the suspension and replaced shocks and tie rods.
New vacuum hoses, rebuilt injectors and all new stainless steel fuel lines.
I have worked my way around the engine, and still need to put a new CHT on as it reads cool.
Any whoo, I did a compression test today and these were my readings.
1. 110
2. 105
3. 100
4. 130
Some big variances there.
Spark plugs are all dark.
Is it rebuild time?
Recommendations on best DIY rebuild sources books, blogs, youtubes, this forum etc.
I want to keep it pretty much stock but am interested in putting the european style pistons in the car.
Any other recommendations and opinions are much appreciated.
Thanks,
Gary
BeatNavy
post Jan 17 2020, 07:30 PM
Certified Professional Scapegoat
Are those cold or hot compression numbers? Yes, they're not great, but they are better than my old 2056 which actually still ran pretty strong. How does it run?
If you are leaning toward, or looking for a reason to, rebuild, then go for it -- it's a good learning experience, but it will cost you more than you might expect. You'll likely end up "wanting to do it right while you're in there." That's not a bad sentiment, it just ends up costing $$, and hopefully you will have a really solid, reliable engine.
In terms of resources, I would recommend:
1. Raby rebuild video
2. Tom Wilson VW rebuild book
3. This forum
4. This guy's site who did a good job documenting start to finish: http://www.ephotomotion.com/914engine/index01.html
Also, make sure you have an end goal in mind before you start buying parts. A 2056 is a nice little upgrade from stock 2.0, if you're willing to do some tuning.
Wew
post Jan 17 2020, 09:11 PM
Thank you much for all the great information and insight. I will research what a 2056 rebuild is. Yes I am game for paying extra now for no regret down the line.
Those compression numbers were done with the engine hot. It runs decent. a little rough and the previous owner put hydraulic lifters in it.
My plan would be to do the rebuild without the hydraulic lifters but again am open to opinion and input. The car will not be a daily driver commuter.
Thanks again for you input.
Gary
Wew
post Jan 17 2020, 11:06 PM
A treasure map from the Haynes manual that came with the car.
Not sure what it means.
Good or bad.
Any interpreters out their would be appreciated.
Wew
post Jan 17 2020, 11:17 PM
One more in the notes.
post Jan 18 2020, 06:59 AM
Did you prop the throttles open when performing the compression test ?
Has the engine been run and driven regularily ?.....or dormant for long periods ?
If you know the paperwork refers to your engine I wouldn't jump into a rebuild without further investigation.
BeatNavy
post Jan 18 2020, 07:03 AM
You may already have a 2056. That's at least what the notes are showing (96 mm cylinder with 71 mm crank). Some of those numbers on there are someone calculating the compression ratio based on combustion chamber and deck height.
Your mystery to solve is: is that what you really have in the car, or is that just someone's scribbling? Only way to know for sure would be to remove heads and measure the diameter of one of the cylinders.
BeatNavy
post Jan 18 2020, 07:17 AM
More info:
CR is the calculated Compression Ratio (either 8.7 or 8.9 in his notes). I haven't run this person's number to check, but CR is going to be based on combustion chamber volume in head (61 cc according to the notes), deck (plus shim) height, stroke (71 mm for stock 2.0 crank). and bore or diameter of cylinder (96 mm, versus 94 for stock 2.0).
Displacement (2056) is based on engine bore (96 mm) x swept volume (71 mm) x 4 cylinders.
2056 is a nice engine from stock as the cylinders drop right in without machining, it doesn't over stress the components, and it can use stock FI induction (with tuning) if desired.
Here, this is something fun to play with: https://www.cbperformance.com/v/enginecalc.html
Bleyseng
post Jan 18 2020, 08:05 AM
Aircooled Baby!
Did you adjust the valves before?
Did run the engine before so it was warm and had oil hot?
Big difference between a cold test vs a warm engine usually.
Wew
post Jan 18 2020, 10:42 AM
No I did not prop the throttle open.
I run it about once a week. Sometimes longer stretches between drives. Typically 3 mile-10 miles cruises.
Sometimes it will sit longer depending on current projects on the car.
Thanks much for the questions and weighing in.
Much appreciated.
QUOTE(rgalla9146 @ Jan 18 2020, 04:59 AM) *
Wew
post Jan 18 2020, 10:49 AM
Wow. Great info. Thanks much for taking the time. It seems like it’s getting close to engine drop time. I am keeping my fingers crossed regarding what lies beneath those cylinder heads.
The car is a fuel injection and the valves are very loud. (Hydraullic)
I have never adjusted the valves on the car.
QUOTE(BeatNavy @ Jan 18 2020, 05:17 AM) *
More info:
Wew
post Jan 18 2020, 10:51 AM
I did run the engine so it was warm
/hot
Thanks for questions and looking forward to your thoughts on my situation.
Thanks,
Gary
QUOTE(Bleyseng @ Jan 18 2020, 06:05 AM) *
Wew
post Jan 18 2020, 11:11 AM
To add to the story of this car.
I bought it 2014.
It was originally owned in Southern California and was used as a trade by a heavy equipment operator doing work on their home.
I purchased the car from the heavy equipment operator who near resided in Joshua Tree
National park, near Mojave desert.
It was a runner when I purchased it. He told me at the time of purchase that the original owner had put hydraulic lifters in it because he got tired of doing valve adjustments.
I don’t know the difference other than when you start up the car and it’s seems for a while it ticks pretty loud. I joke and say it sounds like a lawn mower.
Lots of surface rust. 2 years later car was stripped and painted.The car was crusty to say the least, and have since gone through and cleaned up the interior, new windshield,
All new rubber (thanks 914rubber). Doors, locks, fuel injectors, new as fuel lines, clutch cable, led lighting upgrades all the way around, dash top, rebuild of targa top (almost complete) recovered seats, new sail panel covers, interior tub reinforcement runners brackets (tangerine racing), windshield. There’s more but I can’t remember off the top of my head.
In summary I have gone down the slippery slope and am enjoying every minute of it.
I am not a natural mechanic but read and learn like crazy.
Hence all the information and input everyone shares is invaluable.
Thanks again for reading and all of your input,
Gary
post Jan 18 2020, 11:18 AM
Before removing engine
Re-do the comp test on warm engine with throttles wide open.
You might be pleasantly surprised.
Someone knowledgible enough to measure everything so
thoroughly would never install a hydraulic compatable cam.
Verify what is in there. Maybe a change of lifters is in order.
Maybe there was an in-between owner who committed that sin ?.....
without a hydraulic cam ?
Wew
post Jan 18 2020, 11:25 AM
Here are a couple of photos of it over time.
Wew
post Jan 18 2020, 11:32 AM
A couple more.
Some wet sanding and polishing in progress.
Attached ImageAttached Image
Wew
post Jan 18 2020, 11:36 AM
And one last.
I did decide to badge the car. Yes I have read all the backs and forth.
Personally I love this car and think it deserves the badge.
Thanks again for all the input
Wew
post Jan 18 2020, 11:46 AM
QUOTE(rgalla9146 @ Jan 18 2020, 09:18 AM) *
Ok. I will re do the compression test with the throttle wide open and report back later today.
I am not sure what I am looking for when it comes to determining if there are hydraulic lifters and cams in the car. Any resources or tips on what to look for would be much appreciated.
Thanks,
Gary
ndfrigi
post Jan 18 2020, 03:02 PM
wow congratulations on your beautiful project! For me I will install back that engine and enjoy it as is. Maybe just need some more tuning for now and your good to go! And I think after driving it for awhile, you will ended up wanting to do a 6 conversion.
Wew
post Jan 18 2020, 03:54 PM
Wow. What a difference in readings with the throttle wide open.
1. 160
2. 160
3. 150
4. 170
What conclusions can be drawn from these reading?
Thanks,
Gary
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 16th April 2024 - 02:58 AM
