Best way to refresh rear bumper top |
doug_b_928 |
Aug 22 2019, 07:20 PM
Senior Member Group: Members Posts: 688 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I'm going to need a new front bumper top from 914Rubber, but I'm hoping to save the rear one. It's in really nice shape but it looks dirty, dull/faded (see pic below). What's the best way to bring it back to looking its best?
Mike Fitton |
Aug 22 2019, 07:24 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
I have had luck with 150, 400, 600 sand paper then “back to black”.
Aug 22 2019, 07:31 PM
Wash with dish detergent then Vaseline and leave it in the sun for a bit. Buff with soft cloth.
doug_b_928 |
Aug 22 2019, 08:31 PM
Those are two interesting, and quite unique, approaches. I’ve previously used back to black and it has worked well initially but not held up very well. But that was on a harder material. Would the Vaseline method last longer?
Aug 22 2019, 08:41 PM
Those are two interesting, and quite unique, approaches. I’ve previously used back to black and it has worked well initially but not held up very well. But that was on a harder material. Would the Vaseline method last longer? Depends if it's a garage queen or daily driver. Just re-apply as needed. If the vaseline doesn't work, you can always sand but might as well try easy, first. |
Aug 22 2019, 08:58 PM
914 Wiring Harnesses Group: Members Posts: 8,439 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Rub glycerin into it. It requires reapplication from time to time, but its not petroleum based so it will not deteriorate the rubber.
Aug 22 2019, 10:07 PM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Hot water and soap. Wipe with acetone. Shoot with penetrating vinyl dye.
You should keep most of the texture. Really a matter of cleaning opening up any pours, and the vinyl dye will make it a satin color. This is if the rubber is not too far gone. If it’s wavy the internal structure is failing. You can still use it, but it’s a matter of time. Thanks, Mark |
gereed75 |
Aug 23 2019, 05:48 AM
Senior Member Group: Members Posts: 1,233 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Great tips guys. Not sure it is needed in this instance, but I did a pretty effective repair using black 3M 5200 adhesive. This stuff would definitely work to secure new anchors too. http://www.914world.com/bbs2/index.php?sho...=240803&hl=
With some diligence it might be possible to reskin a bumper top with a “ skim” coat of this stuff. Maybe?? |
doug_b_928 |
Aug 23 2019, 06:18 AM
Thanks to all for the ideas. I’ll weigh my options. I don’t see the VHT vinyl dye locally but I do see Duplicolor vinyl and fabric paint. Does anyone know if that’s the same as vinyl dye (i.e., is vinyl dye a paint)?
Gatornapper |
Aug 23 2019, 06:51 AM
Senior Member Group: Members Posts: 1,186 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
After the sanding, one of the best detailers on the east coast who is a friend says this is the best stuff there is:
https://www.amazon.com/Solution-Finish-Blac...2dDbGljaz10cnVl GN |
76-914 |
Aug 23 2019, 08:02 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
She cleans up nicely. Touch up your valence covers and tires and it will "pop"! (IMG:style_emoticons/default/beerchug.gif)
Aug 25 2019, 10:09 PM
Great tips guys. Not sure it is needed in this instance, but I did a pretty effective repair using black 3M 5200 adhesive. This stuff would definitely work to secure new anchors too. http://www.914world.com/bbs2/index.php?sho...=240803&hl= With some diligence it might be possible to reskin a bumper top with a “ skim” coat of this stuff. Maybe?? Yes it is possible to “Reskin”, difficult to get the texture correct. The problem is that with vibration and heating and cooling cycles it will separate as the base material is over 45 years old and even if glued, will come apart. Maybe you get a year or two, but eventually it will fail. But hey you got an arts and crafts project to keep you busy next weekend. (IMG:style_emoticons/default/biggrin.gif) |
gereed75 |
Aug 26 2019, 05:59 AM
Not sure about skimming but I did that “chunk” repair five years ago and it still looks like the day I did it.
porschetub |
Aug 26 2019, 02:33 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Thanks to all for the ideas. I’ll weigh my options. I don’t see the VHT vinyl dye locally but I do see Duplicolor vinyl and fabric paint. Does anyone know if that’s the same as vinyl dye (i.e., is vinyl dye a paint)? The cleaning and prep is the key to a longer lasting solution,used the Duplicolor and it lasts 3yrs or so if not applied to a clean surface it starts to degrade in about 18 months. The sun here in NZ is rather vicious. I would stick with a product known to be suitable for bumpers,good luck. |
Lo-Fi Version | Time is now: 29th March 2024 - 12:18 AM |
