2.0 Fuel Injectors, Standard FJ67 |
Mblizzard |
Jan 29 2014, 01:35 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I ran across some non Bosch fuel injectors for 2.0 L. They were new and at a really good price. Anyone used these before?
Jan 29 2014, 02:11 PM
914 Wiring Harnesses Group: Members Posts: 8,439 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Those Amazon injectors look like a standard D-Jet case, but who knows what their impedance and flow-rate performance is? They don't say, so we don't know if they are compatible. They could be for a smaller or larger engine.
If you need compatible injectors, see this list: Attached image(s) |
Dave_Darling |
Jan 29 2014, 03:49 PM
914 Idiot Group: Members Posts: 14,974 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Many years ago, I picked up some "Filco" (maybe "Filko"?) brand injectors. IIRC, they tested out as being functionally identical to the stock Bosch ones.
--DD |
0396 |
Jan 29 2014, 07:17 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Thanks, great info
Mblizzard |
Jan 29 2014, 07:27 PM
I ask for the specs per Mr. Bowlsby's suggestion. Got some information but I think it contained a typo as the math in the cc/min to lb/hr was off. When I get the numbers confirmed I will let you know but they seemed really close maybe just a little higher overall.
Mblizzard |
Jan 30 2014, 10:28 AM
OK so I finally tracked down the specs for the injector.
FJ67 Flow rate 415.29 cc/min Weight of fuel lb/hr 40.8 lb/hr Test pressure 248 kPA (36 PSI) These are slightly higher than the stock numbers even when adjusted for the different test pressures. Stock Bosch 0 280 150 019 Flow rate 380 cc/min Weight of fuel lb/hr 37.3 lb/hr Test pressure 300 kPA (43 PSI) I am not sure how the math works to resolve the flow rates for the differing test pressures but assuming it is linear running these at a slightly lower psi 27 would match the flow pretty closely. Certainly no expert here but I thought I would post what I found. |
worn |
Jan 30 2014, 10:39 AM
can't remember Group: Members Posts: 3,129 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
OK so I finally tracked down the specs for the injector. FJ67 Flow rate 415.29 cc/min Weight of fuel lb/hr 40.8 lb/hr Test pressure 248 kPA (36 PSI) These are slightly higher than the stock numbers even when adjusted for the different test pressures. Stock Bosch 0 280 150 019 Flow rate 380 cc/min Weight of fuel lb/hr 37.3 lb/hr Test pressure 300 kPA (43 PSI) I am not sure how the math works to resolve the flow rates for the differing test pressures but assuming it is linear running these at a slightly lower psi 27 would match the flow pretty closely. Certainly no expert here but I thought I would post what I found. Where did you find these? It might be a better alternative to increasing fuel pressure etc for those tuning a 2056 or larger. Having been there, I wouldn't mind the option. |
Mblizzard |
Jan 30 2014, 12:03 PM
OK so I finally tracked down the specs for the injector. FJ67 Flow rate 415.29 cc/min Weight of fuel lb/hr 40.8 lb/hr Test pressure 248 kPA (36 PSI) These are slightly higher than the stock numbers even when adjusted for the different test pressures. Stock Bosch 0 280 150 019 Flow rate 380 cc/min Weight of fuel lb/hr 37.3 lb/hr Test pressure 300 kPA (43 PSI) I am not sure how the math works to resolve the flow rates for the differing test pressures but assuming it is linear running these at a slightly lower psi 27 would match the flow pretty closely. Certainly no expert here but I thought I would post what I found. Where did you find these? It might be a better alternative to increasing fuel pressure etc for those tuning a 2056 or larger. Having been there, I wouldn't mind the option. Oddly on evil bay pretty low cost at $50. Made the seller a best offer of $50 and got them. |
Mblizzard |
Feb 4 2014, 09:48 AM
Ok so I took chance and got one of these injectors. Something seems missing in the comparison of the Bosch injector on the bottom (the green one) to the FJ67.
Close up Am i wrong in thinking the tip is missing? I think the missing part is kind of the most important part of the injector! |
boxsterfan |
Feb 4 2014, 10:49 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Maybe that is how they are able to spray enough fuel? Just dump it in.... (IMG:style_emoticons/default/smile.gif)
worn |
Feb 4 2014, 10:52 AM
Ok so I took chance and got one of these injectors. Something seems missing in the comparison of the Bosch injector on the bottom (the green one) to the FJ67. Am i wrong in thinking the tip is missing? I think the missing part is kind of the most important part of the injector! Looks like they have set back the pintle for some reason. I would give it a try: spray might be better for all we know. And then tell us what went wrong. (IMG:style_emoticons/default/laugh.gif) |
Mblizzard |
Mar 19 2014, 11:36 AM
I can now verify that these FJ67 injectors are a viable substitute. My 2056 is running strong with them and I have not had any problems. They are slightly higher flow rate but that seems to work well for my engine.
watsonrx13 |
Mar 19 2014, 12:30 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Thanks for the information. Did you get a set of (4) for $50?
--- Rob |
Mblizzard |
Mar 19 2014, 01:50 PM
boxsterfan |
Mar 19 2014, 03:16 PM
Mblizzard |
Mar 19 2014, 05:28 PM
ChrisFoley |
Aug 1 2014, 12:54 PM
I am Tangerine Racing Group: Members Posts: 7,894 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I just did an online search for the Standard FJ67 injectors.
Mostly they're out of stock. Lowest price I found was $82 at Rock Auto. My FLAPS checked with Standard and there aren't any available in the USA. At injectorwarehouse.com the listed injector for a 914 2.0 is Bostech MP5119, priced at $35 each plus $8 core. Has anyone used the Bostech injectors? |
Mblizzard |
Aug 1 2014, 12:59 PM
Chris check Amazon they have them for 33. They show a Bosch on the web site but you get FJ67.
I have 2 new Bosch ones if you are in a hurry. |
Mblizzard |
Aug 1 2014, 01:01 PM
Amazon gets them from AUS injection in Tempe Az. Part MP-2307
Mblizzard |
Aug 1 2014, 01:25 PM
Lo-Fi Version | Time is now: 29th March 2024 - 06:58 AM |
