914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3, ADDED RECAROS |
Curbandgutter |
Mar 25 2013, 01:12 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well the dream begins. I'm embarking on the building of a 914 project. Here is the candidate. Bought a roller from LA area. Looks like its not going to be too much rust. Firsts thing will be to strip it. Taking front fenders and rear quarters off. Then sending to Cal Blast for media blasting. I look forward to the knowledge that I can gain from fellow enthusiasts. Plan on taking a lot of pics Stay tuned......
DISCLAIMER: Do not attempt to duplicate anything that is mentioned or illustrated in the entirety of this thread. I do not make any warranties of any kind. If you try to build what I am doing, you take full risk. Do not try this. It may be dangerous to your health and may get you killed |
Mike Bellis |
Mar 25 2013, 07:07 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
BMiller |
Mar 25 2013, 08:00 PM
Newbie Group: Members Posts: 27 Joined: 7-October 09 From: Johnson City, TN Member No.: 10,904 Region Association: South East States |
Welcome aboard! (IMG:style_emoticons/default/beerchug.gif)
pcar916 |
Mar 25 2013, 08:26 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
KaptKaos |
Mar 25 2013, 09:14 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Cool!! Where are you in SoCal?
Elliot Cannon |
Mar 25 2013, 10:15 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Come to the G&R swap meet. Lots of stuff there you will absolutely need. Forget the roll cage. (Unsafe in a street car). Go with the Sheridan body. (IMG:style_emoticons/default/first.gif)
rpmmaxxed |
Mar 26 2013, 02:02 AM
Member Group: Members Posts: 387 Joined: 24-May 05 From: Oceanside, CA Member No.: 4,140 Region Association: Southern California |
Come to the G&R swap meet. Lots of stuff there you will absolutely need. Forget the roll cage. (Unsafe in a street car). Go with the Sheridan body. (IMG:style_emoticons/default/first.gif) Just out of curiosity, why would a cage be unsafe in a street car? |
carr914 |
Mar 26 2013, 05:25 AM
Racer from Birth Group: Members Posts: 118,160 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
and Elliot, wasn't there a Cage in Zonker? Personally I felt a lot safer with a Cage in my car. It was padded |
monkeyboy |
Mar 26 2013, 08:39 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Generally cages are unsafe in street cars because you don't wear a helmet on the street. Since the 914 is so small, it's likely in an accident you will bump your head on the roll cage. In that event, the cage always wins.
andys |
Mar 26 2013, 09:48 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Ok, you got my attention.......which twin cam V8? Which 6 speed? Oh, and yes, where in SoCal?
Andys |
Curbandgutter |
Mar 26 2013, 12:14 PM
carr914 |
Mar 26 2013, 12:19 PM
Generally cages are unsafe in street cars because you don't wear a helmet on the street. Since the 914 is so small, it's likely in an accident you will bump your head on the roll cage. In that event, the cage always wins. There are plenty of other things (some Sharp) for you to hit you head on. |
Curbandgutter |
Generally cages are unsafe in street cars because you don't wear a helmet on the street. Since the 914 is so small, it's likely in an accident you will bump your head on the roll cage. In that event, the cage always wins. I see your point. Thank you for the heads up (pun intended) However, since I am making this a speedster, I'm thinking of moving the rear hoop to be more in line with the back of the firewall. |
Curbandgutter |
Mar 26 2013, 12:23 PM
Come to the G&R swap meet. Lots of stuff there you will absolutely need. Forget the roll cage. (Unsafe in a street car). Go with the Sheridan body. (IMG:style_emoticons/default/first.gif) |
rpmmaxxed |
Mar 26 2013, 12:34 PM
Generally cages are unsafe in street cars because you don't wear a helmet on the street. Since the 914 is so small, it's likely in an accident you will bump your head on the roll cage. In that event, the cage always wins. There are plenty of other things (some Sharp) for you to hit you head on. Never occured to me, but makes obvious sense. |
JoeSharp |
Mar 26 2013, 05:27 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The party thread.
http://www.914world.com/bbs2/index.php?showtopic=206693 The only place you need to be on the 21st of April. |
Curbandgutter |
Mar 27 2013, 10:20 AM
The party thread. http://www.914world.com/bbs2/index.php?showtopic=206693 The only place you need to be on the 21st of April. I'll be there. Joe you are a wordsmith man. Love the "black colloidal suspension known as Coffee, along with fat pills (Donuts for the politically correct) available in the AM". Are we gonna have an "ethereal epiphany of unctuous delight" also known as fat burgers. Anyway back to the topic. |
Curbandgutter |
Apr 12 2013, 11:14 AM
I have most of the car stripped. Making a rotisserie. As soon as rotisserie is completed I plan on media blasting. Looked into media blasting with pressure washer and crushed glass. Looks like that is the way I will be going. I'll post pictures as soon as I complete the rotisserie.
Elliot Cannon |
Apr 12 2013, 11:48 AM
(IMG:style_emoticons/default/welcome.png) and Elliot, wasn't there a Cage in Zonker? Personally I felt a lot safer with a Cage in my car. It was padded The Zonker had a roll cage but I didn't install it. I bought the car as it was. I don't like a roll cage for the street because it just doesn't "give" on impact. Roll cages and roll bars are there to protect you from a roll-over. Every time a chassis or body is bent and crinkled in an accident it absorbs energy and increases the chance of survival in a collision. That's my .02 worth. (although some consider it to be worth about .015). (IMG:style_emoticons/default/lol-2.gif) |
Elliot Cannon |
Apr 12 2013, 11:53 AM
I have most of the car stripped. Making a rotisserie. As soon as rotisserie is completed I plan on media blasting. Looked into media blasting with pressure washer and crushed glass. Looks like that is the way I will be going. I'll post pictures as soon as I complete the rotisserie. I can personally recommend the Sheridan body. They are made here in Paso Robles, are well made and are incredibly strong. I'll be at the G&R and can tell you from my experience how strong they are. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 04:58 PM |
